 Piston for cast iron barrel
1bantamcloser2divorce
Number of posts : 36
Piston for cast iron barrel Empty
PostSubject: Piston for cast iron barrel   Piston for cast iron barrel Icon_minitimeTue Jun 25, 2013 3:48 am
Could anyone advise me on a suitable piston for a 125 cast iron motor on its standard bore?
I understand the stock rings are too brittle for high rpms.
With a "foreign" piston and gudeon pin, what is the best way to  accommodate the piston to the little end?
Thanks, as always for suggestions.
Andy
PostSubject: Re: Piston for cast iron barrel   Piston for cast iron barrel Icon_minitimeTue Jun 25, 2013 5:29 pm
I still have race pistons, that were made for the club, they are single ring and proper jobs, I'm sure I have std bore sizes and lots of over size items, before you purchase if your making a new engine make sure the welding/bronze welding has been done and the bore is ok, we always welded the inlet port then opened up the exhaust first, just incase you break through, that would need welding, then check the bore its amazing how much stress you introduce with doing this, also check it cold and hot by putting a blow torch up the exhaust port, amazing how much this changes the shape of the barrel, some carfull handling needed to avoid burnt fingers and we mad a contraption to hone the barrel in a vice with the four studs clamped up
my advice is to establish pistons after your barrel is finished.
PostSubject: Re: Piston for cast iron barrel   Piston for cast iron barrel Icon_minitimeWed Jun 26, 2013 12:52 am
Good advice, thank you Derek.
PostSubject: Re: Piston for cast iron barrel   Piston for cast iron barrel Icon_minitimeSun Jul 21, 2013 1:46 am
So bronze welding is the modern method of choice? Any suggestions for success I need to pass on to the welder?
Thanks,
Andy
» my cast iron barrel 175
» Making a 1950's style double sided brake
» 186 Cast Iron barrel compression ratio
» aluminium cast Bantam barrel and head.
» will standard barrel take 64mm piston?
