| porous aluminium weld | |
+5ptibbitt125 ROBBIE dansofield550 mm_tribsa les2012 9 posters |
| Subject: Re: porous aluminium weld Fri May 15, 2015 2:42 am | |
| Subject: Re: porous aluminium weld Fri May 15, 2015 3:22 am | |
| Subject: Re: porous aluminium weld Sun Aug 16, 2015 6:48 am | |
| Ryger, eat your heart out! Looking good Nigel , well done! I`ll take half a dozen, collect next week?
Regards, Trevor
| Subject: Wünderbar! Sun Aug 16, 2015 9:16 pm | |
| Subject: Re: porous aluminium weld Mon Aug 17, 2015 8:35 am | |
| Nigel, Just had an email from Derek, he wants two but complete with CVT and, very generously, will give you till next year to deliver! Looks like you are going to be busy then? Do you need cash up front cos Derek`s got none now , could be a problem?
Dead right there John; Wunderbar!!
| Subject: Re: porous aluminium weld Tue Aug 18, 2015 6:08 am | |
| well it fired up ok tonight.... ran for 10 secs.... need to sort out some water to get round it before i let it go any longer. ill try and video it . thought i may have problems with ignition as the rotor doesnt come flush with the coil part, but it started so ..... i have got another project coming up soon Trevor..... as you know..., just waiting for the info to arrive Dereks doing ok , he doesnt need cvt , just slip the clutch more the cagiva barrel is bog standard which gaves 31bhp out the box, but a young fella told me yesterday that his engine was tuned to 42bhp same as whats achievable with the aprilia rs 125 road bike engine. so if i can get the engine and exhaust it to fit the frame , a run on a dyno will be interesting | |
| Subject: Re: porous aluminium weld Wed Aug 19, 2015 7:42 am | |
| Many congratulations for getting the thing to run, albeit for a few seconds on the initial run, I know that a lot of hard work has gone into your venture, many would have given up much earlier, a great credit to you. However, I cant see a standard gearbox and clutch lasting too long with 30+ horse power going through it. Unless you know something we don`t ?
| Subject: Re: porous aluminium weld Thu Aug 20, 2015 5:14 am | |
| Subject: Frankenstein´s brother... Fri Aug 21, 2015 8:52 pm | |
| I've got the wind up -- that picture I saw looked a bit more like Mary Shelley's laboratory for making a replica of Frankenstein than a motorcycle workshop -- and have a feeling Nigel will have a special rider, perhaps looking like himself aboard doing fantastic body leans and late brakings ....
There was a pipe there with what looked like a thing from a dentist surgery where Nitrous Oxide can be metered into the patient´s lungs to have the poor soul laughing his head off whilst still feeling the pain.
And another thing about Nitrous Oxide -- when mixed with another gas and injected into the iintake makes sprint engies go much quicker -- for a short time only, of course.
Perhaps I´d better delete that last bit as being too much of a temptation... Cheers! | |
| Subject: Re: porous aluminium weld Sun Aug 23, 2015 1:34 am | |
| video of the engine running done .... dont know how to stick it on site . probably have to get it on u tube to see it https://youtu.be/NjHr6_8hEqc | |
| Subject: The lawn needs mowing... Sun Aug 23, 2015 6:16 pm | |
| The lawn needs mowing ...
Fantastic pipe and why two? -- noise and neighbours I suppose....
Well done Nigel!
Go well and stay well... | |
| Subject: Re: porous aluminium weld Sun Aug 23, 2015 8:01 pm | |
| Yes, well done Nigel, a just reward for tenaciously pursuing your project and to get it running. Donuts and beer are on me when meet up again! Nice pipe, completes a fine piece of creative engineering.
Pity about the dorks on KB, what do they know!!!!!
Regards Trevor. | |
| Subject: in frame Fri Sep 18, 2015 11:36 pm | |
Last edited by nigel breeze on Mon Oct 12, 2015 12:41 am; edited 1 time in total | |
| Subject: more pictures Sun Oct 11, 2015 11:25 pm | |
| updated extra pictures. | |
| Subject: Re: porous aluminium weld Mon Oct 12, 2015 12:35 am | |
| Nigel, very professional, impressive and a great credit to you, I hope we shall see it at the Avenue in November?
The Bathhurst pictures will be interesting and are very reminiscent of the early DKW set up with duplex, case and cylinder inlet, see if I an dig out a picture or two for comparison!
Cheers, Trevor | |
| Subject: crankcasse cooling Sat Oct 17, 2015 6:13 am | |
| i think probably second phase transfer plenum... maybe needs shrinking a bit to 125cc may be less... but better use of space than water cooling? and after all the issues i had getting it to seal has been beneficial... i wonder what’s the smallest reed valve you can get without having to knock one up yourself? | |
| Subject: Re: porous aluminium weld Sat Oct 17, 2015 9:52 pm | |
| Nigel, If you can fill that annular chamber with mixture do you think you can shift it all in .002s of transfer phase at 11,000 rpm, it`s a long way from the bottom of the radius to the combustion chamber, perhaps better to pump cool water through?
Terrific engineering though, marvellous stuff, love to see it at the Avenue!
Cheers, Trevor | |
| Subject: Re: porous aluminium weld Tue Dec 01, 2015 8:06 am | |
| had to ditch the ducati ignition as it was playing up, cobbled together an aprilia rs 125 system. as i had most of the bits. carb has standard jetting which is not to clever 1/4 throttle but once through that, revs out nicely/ noisily could be that the exhaust power valve is held open. i need to have the exhaust modified slightly to fit , but its such a nice pipe its going to kill me to cut and weld. the pipe is an arrows which the welding is beautiful, be surprised if i can find anybody to match the quality. im a bit worried about the the offset sprocket i put together, the weakest link as of now..
https://youtu.be/925oGR4Ljpg | |
| Subject: Re: porous aluminium weld Mon May 16, 2016 7:00 am | |
| after taking bike up the road for a quick spin... it flew... then it stopped:( ... my barrel base plate sprung a leak:scratch: ... should have loctite securing bolts also my mk1 offset sprocket failed but almost ready for another run out | |
| Subject: Re: porous aluminium weld Fri Dec 30, 2016 5:00 am | |
| Subject: vASELINE ::: Fri Dec 30, 2016 5:06 am | |
| A little vaseline works wonders-- blokes in our room in the army school used it on their hair....
...how daft can you get.
Looks very good Nigel -- on ´the sink ????
Have a good and happy new year!
John-Boy. | |
| Subject: Re: porous aluminium weld Fri Dec 30, 2016 5:17 am | |
| i thought i would paint it again..... and put some stickers on it so it looks like a proper bike i did try it up the road a couple of weeks back... scared me to death, it was a bit damp and the back came round not too bad on mx bike on mud, but im getting to old for that now on a road | |
| Subject: Re: porous aluminium weld | |
