  I need HELP
5 posters
 I need HELP  Empty
PostSubject: I need HELP     I need HELP  Icon_minitimeSat Mar 17, 2012 7:58 am
I need an under plug TEMP SENSOR, and gauge.
who do i get one from and how is the best way to set it up.
if anyone can please help - with an address or the type of gauge needed.
as I will need as much help as possible, in how to set one of these up, seems I have made some school boy errors, as a result the bike seized on the Dyno, this afternoon, i have just finished stripping it my goodeness "f" the damage in the engine is extensive, More importantly I have been told, I could have see this comming, "with an air cooled engine" if I had and underplug Temp sensor and gauge,
we were marginal with the fuel air charge, and doing a longer run than normal, if we had and underplug gauge we would have seen this or so a guy who is far more knowlegable them me.
kind regards to all.
Number of posts : 367
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeSat Mar 17, 2012 9:08 am
whilst at the london bike show i was chatting to a guy at digital speedos .co.uk
he had nice rev counters that done all sorts of thing , also an under plug temp sensor heres a link, its only £20 for the sensor but 139 for the rev counter that it plugs into.
http://www.digital-speedos.co.uk/temperature-sensor-for-airoil--cooled-engines-28-p.asp
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeSat Mar 17, 2012 7:42 pm
hi can you help me - you where overheared in the paddock saying one of these gauges was not difficult to make, could you explain this, and
bolivians yes hmm "I dont trust them" especially the women !.
Gliders I have been PM that powered gliders have these, could anyone suggest an underPlug type of gauge or sensor
So come on I know lots of you are aware of this gauge, as I want to get the correct item, I have been Pm that it seems the piece that goes under the plug (are several makes) are prone to failure, some more robust than others,
could some one help me here, ? 1) what should I be asking for and 2) from where or who should I be talking too?.
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeSat Mar 17, 2012 7:59 pm
Hi Dan
Taken a look at those, thanks they look very nice, just not sure its the correct one should be using but certainly for consideration, the type I can vagely remebr seeing are the ones on there own and have a round gauge showing a temp analoge display with numbered dial so we know where it should be, these are not digital
if I could get a digital item we may be able to get one that saves the highest recorded temp in a momory, these must be about,! and some one hopfully can comment who has purchased or used them!.
regards. Derek
Colin Oldham
Colin Oldham
Number of posts : 35
Registration date : 2011-09-01
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeSun Mar 18, 2012 3:01 am
Well then, Sent you a photo, Rang your mobile, home, work to tell you can buy them off eBay, they are called “Trail Tech TTO Temperature Meter Digital Gauge 14mm Spark Plug Sensor” and cost £25.00 plus P&P £4.00 From the USA, that is where I got mine.
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeMon Mar 19, 2012 1:16 am
thanks Colin will take a look
been trying to contact you too have you changed your mobile as the old number is unobtainable
cheers Derek
Colin Oldham
Colin Oldham
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeMon Mar 19, 2012 8:13 pm
Hi Derek
Did you get the photo I sent from my phone, the sensor only took 5 days to get to me
I got it last year, but I am sure you can still get them.
I will be at the meet too.
Number of posts : 282
 I need HELP  Empty
PostSubject: VDO Cyl head temp Gauge    I need HELP  Icon_minitimeTue Mar 20, 2012 12:37 am
http://www.machine7.com/section.php?xSec=1173?xSec=1173
The picture shows gauge calibrated in degrees F. Enquire if deg C version available.
I found anything over 200 deg C with my set-up, was likely to seize.
Hope this helps
Pete
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeTue Mar 20, 2012 7:19 am
Hi Peter
ref you E-mails, and the process of properly profiling a new piston, prior to installation and blasting in earnest. Just wanted to feed back my success in stopping the scuffing, since I have been following this very simple process, we have had no scuffing on the exhaust sides per our mails.
Also there is no or little evidence of blowby under the rings, before we would run a piston in, it had a band of carbon under the rings, Now the lands under the rings after the running in process are much cleaner and no signs of any scuffing. ! (thats when I get the jetting correct)
I think it would be helpfull to others on here, would it be ok for me to load it, or better still could you forward it to Alan, he may wish to stick it under the technical tuning page, as its very useful information. !
I hope your well Peter.
Kind regards Derek.
 I need HELP  Empty
PostSubject: New Piston Preparation process    I need HELP  Icon_minitimeWed Mar 21, 2012 10:10 pm
Hi Derek,
Glad it helped. Yes I will ask Alan to put it in the tuning section.
BTW I hope to be at Mallory tomorrow just to have a look. I am pleased that Mick Scutt has taken over my mantle of oldest rider! I wish him deserved success.
Pete
1bantamcloser2divorce
 I need HELP  Empty
PostSubject: Re: I need HELP     I need HELP  Icon_minitimeFri Aug 01, 2014 6:11 am
I am using an under plug TEMP SENSOR, and gauge, similar to those described above.
Could someone give me an idea of what the approximate temp readings should be for a cast barrel bantam.
"I found anything over 200 deg C with my set-up, was likely to seize." Is that a fair rule of thumb for a cast iron barrel?
Many thanks,
Andy
 I need HELP  Empty
I need HELP
