 Amal Mk2 carb power jet addition
Number of posts : 256
PostSubject: Amal Mk2 carb power jet addition   Thu Feb 18, 2016 7:49 pm
My 185 is now running very well on new Amal Mk2.
However, on long fast straights on full throttle, fullflow, it leans out and EGT goes ballistic!
Despite huge adequote main jet.
So, I am thinking of adding power jet kit.
Does anyone have any advice on how to change jetting when adding a power jet?
I can not use a Mikuni in our classic class
cheers
John
PostSubject: Re: Amal Mk2 carb power jet addition   Thu Feb 18, 2016 8:29 pm
John sounds like you may have a problem with the air correction jet, richen up the top end by popping in a revised diameter insert. I personally found that for the w/cooled engine running a 34mm MK2 with a power jet was a waste of time and the engine ran sweeter with out it, besides, who needs the complication. The electronic system on the Honda RS now that was essential, and allowed for maintaining reasonable power right up to 14,000rpm
The conundrum is that the traditional power jet richens, whilst the electronic weakens!
What temperature are you reading when the alarm bells ring? Too much retard at peak torque can dump a lot of heat into the pipe and raise temps there, but is not necessarily detrimental to the engine, too hot a plug grade doesn't help, lots of possible causes but diagnosis can be tricky. Be interested in how you overcome the problem, keep us posted.
PostSubject: Re: Amal Mk2 carb power jet addition   Thu Feb 18, 2016 11:45 pm
I never had any luck with the amal (I tried a mikuni power jet on it too, that was no help)on my 175, it just wouldn't run nice , static it'd seem fine , riding it had no bottom end fueling right and top felt odd too, switched to lectron and you'd think it was a different motor
PostSubject: Re: Amal Mk2 carb power jet addition   Tue Feb 23, 2016 11:59 pm
John,
I was looking through one of my note books from the late 90s on an unrelated matter and came across some details for the 34mm Amal with the power jet installed that we tried, you have probably resolved the issue now but here are the details any way!
Main jet................ 320
Power jet/main...... 80/240
Cheers, Trevor
