| my 175... mikuni.. | |
| Subject: my 175... mikuni.. Sun Feb 12, 2017 9:17 am | |
| https://youtu.be/1z-gkglGxqE afr metering thing had some bits for trying this out for a while, oxygen sensor and gauge. i had hoped to make it for probing inside the exhaust but the sensors bulbous size stopped me . so i cobbled this together to See if it would work,, well the gauge showed something!!.. now maybe i should tidy it up get it all in a box so it looks less rough from a static point of view and if the gauge is correct i think im somewhere near to whats needed but under load this could be very different. which brings me back to that frustrating situation of having nowhere to test it in real terms. | |
Jimmie
Number of posts : 166 Registration date : 2011-07-25
| Subject: Re: my 175... mikuni.. Sun Feb 12, 2017 11:15 pm | |
| Hi Nigel
When I clicked on the links I got a request to sign in. Guidance please. Even if I don't understand the instructions I may feel better. What a stupid machine I have! | |
| Subject: Re: my 175... mikuni.. Mon Feb 13, 2017 4:32 am | |
| ok, sorry looks like i hadn’t ticked a box on the you tube account. it even asked me to log in . should be ok now. i have decided to get hold of a temp gauge as well to see if i can measure the exhaust gas temp . | |
Jimmie
| Subject: Re: my 175... mikuni.. Mon Feb 13, 2017 6:59 am | |
| Subject: Re: my 175... mikuni.. Sun Feb 19, 2017 9:00 am | |
| oh dear, looks like i need a new conrod and big end bearing.. . ill post some pictures of damage....could have been worse. i had a t&g conrod but its design wasnt up to the job for this application.. aah well .. i did show the conrod to derek some time back and he felt that the lack of a slot in the big end of the conrod would cause poor lubrication for the bearing.. seems he was right.. | |
| Subject: T & G rod Sun Feb 19, 2017 3:07 pm | |
| Sad but interesting news Nigel.
My T & G rod in 186 has done some 20hrs hard work without worry. But it has a slot in big end eye. Will put micrometer on pin and rod when it comes apart this winter | |
| Subject: Re: my 175... mikuni.. Mon Feb 20, 2017 2:10 am | |
| Subject: Re: my 175... mikuni.. Tue Feb 21, 2017 2:22 am | |
| Nigel, Been enjoying your video clips and what you have been trying to do, have a load of questions to ask but will wait until a bit later in your experimenting. Can`t imagine what goes on in the design department of some of these rod manufacturers, to omit the proven benefit of slots in a big end eye is absurd. Not only does cooling lubrication get at the cage and pin but heat gets centrifuged out, an easy win, win. Sorry about your travails but hey that`s the learning curve, but one we could all do without. Top work as always Nigel!
Cheers, Trevor | |
| Subject: Might it be the cage Tue Feb 21, 2017 5:27 am | |
| The only big-end trouble I ever expereinced with both Icarus-1 & Icarus-2 was with the bearing cage centrifuging itself to rub on the big end eye in Icarus-1. Just five minutes on the lathe skimming the cage and our problem was solved.... We assumed that with the cage rubbing on the brig-end eye it expanded sufficient to lock the rollers.
Maybe it is notthe case with your problem Nigel....?
Of course neither Bantams ever revved to 12,000 rpm but Icar-2 got to >11,000 but only suffered piston destructions... | |
| Subject: Re: my 175... mikuni.. Wed Feb 22, 2017 6:28 am | |
| yes John, i anticipated a piston seizure, with it being a cast barrel... (4 transfers and a little boost port.... ) but i had been pre warned the conrod would not be up to the job. | |
| Subject: Re: my 175... mikuni.. | |
