Share
 crank pin hole
Number of posts : 358
crank pin hole Empty
PostSubject: crank pin hole   crank pin hole Icon_minitimeSat Feb 25, 2017 9:07 pm
So... can anyone tell me, if you want to increase the crankpin size of your crank to 22mm.... what size hole is required in the crank webs...i had some other crank wheels (suzuki)enlarged to accept a 22mm crankpin but wow how loose where they. pale .. crank still in cupboard unusable in the present condition. i would think that there must be a calculation required or a chart to refer too study
Number of posts : 366
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeSun Feb 26, 2017 9:11 am
Get a Zeus book
Number of posts : 904
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeSun Feb 26, 2017 10:45 pm
crank pin hole Assemblage%20001_zpsdeekufcc
Nigel,
       A little context; John Rennick of Epimetheus fame has a 1600cc nitrous breathing 125hp Vincent engine. The crankpin of the EN36 crank has a .006" interference fit with the crank-discs, and .005" with the mainshafts.
Now I recon with your more modest 25, or so, hp Bantam running a 22mm pin, you need around .002"/ .0025" interference fit with the discs. My w/c engine`s crank runs a .002" interference fit and it has never moved.
The picture is of my currently moribund air-cooled engine project, What I do is bore each disc for the mainshafts, then bolt the two together with a hollow sleeve and a length of studding. The crankpin holes, are bored as one, this ensures all bores are parallel and coaxial, job done.
Hope this is what you need, Trevor
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeMon Feb 27, 2017 6:16 am
Trevor, thanks for info... spent most this morning googling zuse and couldnt understand how a cat in a hat would be of any help... lol!( no offence ment dan but:lol!: lol! lol! )
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeMon Feb 27, 2017 6:21 am
oh, by the way, those crank cases dont look standard lol! but then again looks like rules are only a guidance lol! lol! lol! lol!
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeMon Feb 27, 2017 6:36 am
it has tables to tell you how much you should leave in the hole or on the shaft depending if you want a an interference transition or clearance fit, and according to the dia it will say the amount needed, simples ! I have a Zeus book , but its a- cold out side and b- I don't think I could just go and find it with out going through ton of boxes in the garage since I've moved ! but I would make it 0.002 max tight, warm it up and you can fit it by hand, don't hit it or press it, if you need that then the crank wheel is too cold , zeus book I think also has co-efficient's of linear expansion too
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeMon Feb 27, 2017 8:11 am
crank pin hole Zeus_zps6kmi5hwd
Zeus table of fits, straight out of my metric copy, not too much here about the rough and tumble of Bantam crankpin fits though
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeMon Feb 27, 2017 8:40 am
Thanks Dan and Trevor.. once opened up to the required size do you have to reheat treat ? scratch
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeMon Feb 27, 2017 10:40 am
k6 -n6 fit, roughly 15-26 microns in the upper limits of those fits, heat treat? whats it made of? was it heat treated before? ,as it'll most likely get hot frequently i'd guess its not too much of a problem heating it up, an oven is ideal (gas mk8 ! 200c)a blow torch would be bad if too localised and fierce
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeWed Mar 01, 2017 6:09 pm
Dave, my precision engineer mate made 22mm crankpins for 186cc D7 flywheels, in EN36 I think. Bored holes, lapped to 3 thou fit.
Takes a few tons to press, but stiff as a .......... !
Shortened same pins for TZ250 rod for short stroke 125 too.
He makes them over size, then ground for clearance.
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeSun Apr 09, 2017 9:06 pm
morning everybody..,
found some crank wheels with 22mm crank pin... only the shafts need correcting.. maybe cheers
crank pin hole Img_2013
crank pin hole Img_2014
PostSubject: Re: crank pin hole   crank pin hole Icon_minitimeSun Apr 09, 2017 9:12 pm
crank pin hole Img_2020
[/url]crank pin hole Img_2017
crank pin hole
» Soak Hole Pumping.
» How do i repair a hole in a fuel tank?
» need help quick! Kohler Command wont crank.
» Set of 4 17" 8-hole wheels off new FJ
» mineral pond or water hole food plot
