Share
 A good read
Jimmie
Number of posts : 165
A good read Empty
PostSubject: A good read   A good read Icon_minitimeSat Sep 30, 2017 8:51 am
Just found my long lost copy of Kevin Cameron's book Top Dead Centre. This is a collection of 'the best of Kevin Cameron articles from Cycle World  covering interviews with top-notch racers, profiles of builders and engineers, analyses of riding techniques etc. Wonderful read, even if I did not understand the text at times which most Bantam racers, no doubt, will already know!
P 48 has the following piece which gives an idea of his writing style. Here he comments on the introduction of  a 'restrictor rule' for the 1978 Daytona races which necessitated  a 'washer' be fitted into the inlet in an effort to reduce top speed. This caused endless problems in fine tuning  engines especially for the privateer:
'Here is what I think. Since some setups needed big sets while others tolerated small ones, couldn't this indicate that two states of flow  were possible in the inlet system? One flow would transmit a strong metering signal to the carburettors, while the other attenuated that signal, requiring big jets. Could not a given intake system produce both types of flow, but at different engine speeds? If the strong-signal type of flow persisted well up into the rev range, then abruptly switched to the weak signal, carburetion would lean out and seizure could result.'
And on p 196:
'Usually, the reason for using a particular carburettors is not because it flows more air in (that's what bigger carburettors are for) but because it delivers a mixture curve suitable for the application.'
A good read Empty
PostSubject: Thanks again Jimmie...   A good read Icon_minitimeMon Oct 02, 2017 5:56 am
Thanks again Jimmie!
I look forward to seeing some answers.
Very crude way of ensuring a lowering of performance. In China in 1987 -- phwew! ancient! -- I was shown how the military ensured the motorycyle riders (Don-Rs I suppose) bikes had a restrictor plate after the carburrettor which they said ensured low fuel consumption and that the speed limit was never broken.
Was very Chinese to me!!
A good read
» Some info on PDC from a Swindon fan - good read
» A very Good Read
» a good read (IMO)
» Good Read (Dec 18th)
» Good read on IT and Celtics choices...
