Share
 Bantam Bits
Number of posts : 146
Bantam Bits Empty
PostSubject: Bantam Bits   Bantam Bits Icon_minitimeWed Feb 07, 2018 4:12 am
To continue,( close ratio gears.)
1x19 tooth main shaft, 2x28 tooth bottom gear lay shaft gears, 1x23 tooth main shaft sliding gear, 1x 25 tooth lay shaft sliding gear(2 dogs missing), 1x23 tooth pressed on gear on lay shaft,and 1x23 tooth pressed on gear loose.
There is I think a 4 speed cluster but missing 3rd main shaft sliding gear,(know nothing about these).
1x Borrani WM1/16-18/40 Bantam real wheel, there is a brake plate but needs painting, the wheel runs true.
If interested call me but please be sensible with offers as I'm doing this for a good friend.
Les2012.
Bantam Bits
» Bits 'n' Bobs
» D'Y Loses in Bantam Finals to Fletcher's Meadow 46-39
» Bantam Tournament Mississauga SS Feb 3rd -Feb 4th
» St Roch (Brampton) Bantam Boys Basketball Tournament
» Top 20 Teams 1998 Major Bantam
