 125 pistons
5 posters
andy
Number of posts : 14
Registration date : 2008-06-24
125 pistons Empty
PostSubject: 125 pistons   125 pistons Icon_minitimeTue Jun 24, 2008 11:55 am
Could someone tell me what pistons the 125 racers are using? Thanks
Number of posts : 156
125 pistons Empty
PostSubject: Re: 125 pistons   125 pistons Icon_minitimeTue Jun 24, 2008 9:07 pm
RM125, YZ125 amongst others Wink depends on barrel, some running water cooled specials others on BTW ally barrels.
You got a Race bike or building one?
Tony
andy
125 pistons Empty
PostSubject: pistons   125 pistons Icon_minitimeTue Jun 24, 2008 10:34 pm
I am putting together a 125 to race in the states. I am almost done with most of the work. I will be using an D7 barrel, since I am not allowed to run a water cooled.
andy
125 pistons Empty
PostSubject: 125 pistons still need help   125 pistons Icon_minitimeMon Jun 30, 2008 2:12 am
So, does anyone have a suggestion for what piston I should use with a D7 barrel? Any help would be appreciated. Thanks
andy
125 pistons Empty
PostSubject: 125 pistons please   125 pistons Icon_minitimeSun Jul 06, 2008 2:54 pm
I could still use some help. Is no one willing to help? I know I am not racing in the UK but I thought that Bantam racers were always willing to help each other.
Thanks, Andy
125 pistons Empty
PostSubject: Re: 125 pistons   125 pistons Icon_minitimeSun Jul 06, 2008 5:12 pm
Hi Andy you could try early tz piston which comes out at just under 54mm
that has a peg at the baack center so you can get away with a large exhaust port but it will be 2mm over std. but ok if your running 54mm stroke
hope that's some help
Robbie (52)
andy
125 pistons Empty
PostSubject: 125 pistons   125 pistons Icon_minitimeTue Jul 08, 2008 2:10 pm
Robbie, thanks for the info. Sorry to read about your leg. I wish you the best.
Andy
Number of posts : 282
125 pistons Empty
PostSubject: 125 Pistons   125 pistons Icon_minitimeThu Jul 10, 2008 2:38 am
Hi Andy,
Lets assume you are intending to run an air-cooled piston ported 125, using D7 barrel. I run the same barrel on my reed valved 125 Formula Bantam.
I think the problem may be that most pistons these days are desighned for reed valve induction, and thus if you are piston ported induction, you may have difficulty finding a pistn with a long enough inlet skirt.
However, if you get on to Wiseco, they may have something suitable. and being forged, seem the most robust. Based on my machine, I don't think you need worry about the ring peg position too much, as long as it is behind the two transfer ports.
Bear in mind that you need to look for an air-cooled original application , as the water-cooled pistons will have too shallower taper rate on the skirt. Unless of course you enjoy piston re-profiling...I don't!
Do your regulations allow you to sleeve the barrel? If so, this is highly recommended for reliability. I use a centrifugally spun cast iron liner in my barrel. Using a 56mm YZ125 piston circa 1985, I end up with a liner wall thickness of about 7mm. Nice and stable under adverse temperature stress. It also a proper surface for the piston to bear against, rather than the somewhat non-homogeneous nature of BSA cast iron.
Hope this helps.
andy
125 pistons Empty
PostSubject: re 125 pistons   125 pistons Icon_minitimeThu Jul 10, 2008 3:41 am
Thank you for the info. My barrel has been sleeved. It was made to the specs of the 54x54 race engines but I can't use reed valves.
125 pistons Empty
PostSubject: 125 Pistons   125 pistons Icon_minitimeSun Jul 13, 2008 6:20 pm
Alan I have used Suzuki RG250 pistons in my aircooled 58mm stroke 125. I think two pistons have lasted for some 8-9 seasons on and off moderate use. I respect Alan Browns wisdom and experience, but I used these with out reprofiling, 2.5 thou clearance in a 3mm liner in a 150 cast iron BSA cylinder. In my short stroke moter (also piston ported but water cooled) I used to use early aircooled RM125 Wiseco, but now use 56mm later wc RM125 to make use of 15mm piston pin in 16/20 RD250 rod. You could go out to 57 or even 59 or 60mm with various Wiseco KH400, RG150 or KR150 ; they are all case reed so have long enough skirts.
andy
125 pistons Empty
PostSubject: re 125 pistons   125 pistons Icon_minitimeWed Jul 16, 2008 10:12 am
John, thank you for the information.
Andy
125 pistons Empty
125 pistons
» Pistons for new 175 engine build.
» will standard barrel take 64mm piston?
» Yamaha piston cracking
» Reliability in racing
» suzuki pe 175 pistons
