| 175 con rod | |
Paul Brown
Number of posts : 10 Registration date : 2007-02-19
| Subject: 175 con rod Fri Apr 06, 2007 3:13 am | |
| Why has the 175 bantam con rod to be 125mm?
ATG has machining faclities that can machine barrel and crankcases.
Paul | |
| Subject: con rod Fri Apr 06, 2007 6:06 am | |
| Hi Paul Thanks for email I replied but had it returned?! Don't know of the kwak con rod ? Have a look a 175 spinter bit in Tuning info on this site. Just a reminder the crank determines the stroke , not the rod so any length rod will do as long as the machining of cases and barrel remain within the rules ..... See you on sunday | |
| Subject: Re: 175 con rod Fri Apr 06, 2007 7:42 am | |
| - Paul Brown wrote:
- Why has the 175 bantam con rod to be 125mm?
Paul Hi Paul I'm sure you've seen this already but here's the link if you haven't http://www.bsabantamracing.co.uk/bikes/build175.html No machining is allowed on the crank cases (175s) also not a lot of meat on the bottom of the barrel/inlet port. So rod 125mm btc is what almost everyone is using. The maico rod situation is being sorted also alternatives are out there. pm me your number and I'll call you and have a chat if you like Tony ps I won't be at mallory, off the road at present | |
bennion
| Subject: Re: 175 con rod Sat Apr 14, 2007 1:08 am | |
| I've had 10mm machined from the base of the barrel, excluding the inlet stub area, to suit a 115mm conrod. The crankcase remains externally unaltered - as per 175cc rules. Chris | |
| Subject: Re: 175 con rod Sat Apr 14, 2007 1:43 am | |
| Paul Couldn't reply to your email, so sent you a PM and mail from this site Chris is this with a BTW barrel? didn't seem that much meat on my 175 barrels/inlet, be interested to see how it runs | |
bennion
| Subject: Re: 175 con rod Mon Apr 16, 2007 6:25 pm | |
| Tony Its a cast iron barrel, D7 I think, with 60mm stud cts. A 10mm skim off the base takes it to the next fin up where there is a decent mating face and easier access to the transfer ports. A little gymnastics required at the inlet via some internal crankcase cutting but otherwise it fits well and remains within the 175 formula. Under the formula, BTW barrels have to remain externally unaltered anyway. First outing is either Croft or Anglesey. Chris | |
| Subject: Re: 175 con rod Thu Apr 19, 2007 6:01 pm | |
| - bennion wrote:
- Tony
Its a cast iron barrel, D7 I think, with 60mm stud cts. A 10mm skim off the base takes it to the next fin up where there is a decent mating face and easier access to the transfer ports. A little gymnastics required at the inlet via some internal crankcase cutting but otherwise it fits well and remains within the 175 formula. Under the formula, BTW barrels have to remain externally unaltered anyway. First outing is either Croft or Anglesey. Chris Thanks for clearing that up Chris, knew you can't take much off the BTW without breaking through. If your devolopments work it gives 175ers another option. Variety the spice of life ps Chris how much did Maxtons charge to do your forks? | |
bennion
| Subject: Re: 175 con rod Fri Apr 20, 2007 2:18 am | |
| Tony To shorten the forks and replace the springs and bushes was about £125 from memory. Ouch yes - but lots better than a few very scary looking projections threatening to get stuck up yer nose! Chris | |
| Subject: Re: 175 con rod | |
| 175 con rod | |
