 Gearbox selector mod...
Gearbox selector mod... Empty
PostSubject: Gearbox selector mod...   Gearbox selector mod... Icon_minitimeMon May 02, 2011 7:19 pm
This is for John Sendall and any other interested parties... my advise is don't mod anything until you
have a problem!! As a mod can sometimes create a problem (at first).
This is the selector mod where the weak spring dished washer(or washers) pin with hole and roll pin
are replaced with:- 7mm grond down shank bolt, short tube brazed to fixed selector plate over which a std bant clutch spring and washer/nut are used. If 7mm is to small in the selector pivot holes it will tend to jump out of gear. If 7mm is to big you can't get it out of a gear. Hence why I needed a 7.15mm pin over the closed season. 003 went from jumping out of every gear(had to be held in with foot) to not able to get out of bottom gear...nothing is easy....
Gearbox selector mod... May2011009
Gearbox selector mod... May2011010
Couldn't show you mod in detail as time was short, and 001 was having a major service - conrod/big end assy, piston, mains all 2, g/box bearings all 5 plus broken gear replacement....
PostSubject: Re: Gearbox selector mod...   Gearbox selector mod... Icon_minitimeMon May 02, 2011 10:20 pm
what gear you broke mike 22/24 Press on gear - if so - did it take out top sleve gear too 23/25!
how long since the last time you changed these and are you using std or 003/005 c fit bearings - Please tell us trufully !
PostSubject: Re: Gearbox selector mod...   Gearbox selector mod... Icon_minitimeWed May 04, 2011 10:06 am
It was a tooth off the mainshaft! Don't change gears unless they are broken or a gearbox problem manifests itself check them for wear and replace after a guesstimate of g/box problem.
Std fit bearings are used.... but the EE8 needs to be a 10 ball .. Rex Caunt has some and cheap too.....? Think they are C3 too?
Who is going to sit in judgement over my bearing fit/size??
» Bantam racing project
» Gearbox
» Gearbox pic's
» Gearbox Nasties...
» Gearbox confusion
