 Food for thought !
PostSubject: Food for thought !   Fri Oct 28, 2011 3:21 am
To any or all.
If ignition spark duration was in the order of 1milli second, then, at 12,500 rpm on a 54 bore the
whole combustion process would have been completed in less than that time frame !
This assumes a good quality fuel and a favourable, stoichiometric air/fuel ratio . I worked this out
for the RS Honda , so a lower reving Bantam , and particularly a 175 with it`s bigger bore , would
have a different time frame . Makes you think though , and does illustrate the critical necessity for purity of
trapped charge , high turbulence and spark intensity within a compact combustion chamber .
Hope this one runs a bit, we might have another "Heavy Crankshaft" if we are lucky! It could raise a
lot of peripheral, but related , issues as well !
Regards Trevor
PostSubject: Good Quality fuel....???   Fri Oct 28, 2011 5:19 am
Comes back to that -- I think, Trevor -- every time: a fuel that has the properties of high anti-knock, low peak combustion pressure and long heat-release-rate period AFTER TDC***....
And 175 -- bigger bore with longer flame path? --- uh oh! I think I am out of my depth...?
Hum hum hum...
***{[(tetraethyl lead -- illegal...)]}
Whoops! afterburn -- once the fire starts is the spark duration important...?
PostSubject: Re: Food for thought !   Fri Oct 28, 2011 8:19 am
another crankshaft subject, all theory" what about we did, this, that, and found this worked as a result by ging x more TORQUE/ POWER / RPM,S. !
"its almost like you guys a trying to dangle a carrot, what about some information we can use.!
PostSubject: Re: Food for thought !   Fri Oct 28, 2011 8:44 am
Now i for one dont anything about this subject,
Is it possible to explain it a bit better in laymans terms, we are 175 newcomer's/builders. John/Trevor are you able to expand on this?
PostSubject: Re: Food for thought !   Fri Oct 28, 2011 9:05 am
"Here we go !
your going to start John (JB) off again.
i can just see this is going to be a 5000 "lookin" and 300 post responce topic!!!!!!!!!!!!!.
What about some substance.
PostSubject: Re: Food for thought !   Fri Oct 28, 2011 9:22 pm
ref my last Post comments what Im talking about is please refer to MSCUTT post, This is set out full of information in language i can understand and with direction on how to follow this up.
clearly its not full of WOW na shakespear quotes, or riddles and guess work on what the hell is beiong spoken about.
Thanks Mick Scutt what a great post" - I remeber as kid of 12/14 ready micks helpful and informative comments on tuning and racing a Bantam in the club mag.
Regards Derek
Guest
Guest
PostSubject: Re: Food for thought !   Fri Oct 28, 2011 11:02 pm
You are not obliged to read any of these posts if they are not "your cup of tea", could I ask if you are not interested you ignore them so those of us who wish to take part can do so without having to navigate past your inane ramblings.
Many Thanks
James
PostSubject: I agree James...   Sat Oct 29, 2011 5:52 am
deleted....!!!!
Food for thought !
