| Att Derek - Mota Software | |
| Subject: Att Derek - Mota Software Thu Nov 10, 2011 12:20 am | |
| Dont know if this is any help
If you have a MOTA version 6.00 numbered #24119 up to #24177 and wish to run it on a computer under Windows XP®, you will need to download an updated driver for the hardlock. To do this, download hldrv32.exe from http://www.aladdin.de/support/hardlock_setup_programme.html and execute it (double click hldrv32.exe in the download folder ) AFTER installing the MOTA programme suite from the CD.
If any problems are encountered after you upgrade your computer system to a faster machine, visit the Aladdin site as above and perform the download and upgrade your hardlock driver to the latest version. We have encountered problems ourselves as speeds have gone from 1GHz to 3GHz in just the last 12 months alone.
FAQ #4 MOTA will not usually work on any PC using a Celeron processor , nor with Winbond chips.
FAQ #5 As from August 2005 MOTA uses a Feitian brand Rockey USB style dongle. This is not suitable for use with a 64bit operating system. We are waiting on the manufacturer to add this ability, so for now we cannot supply MOTA to run on a 64bit computer.
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 8:36 am | |
| many thanks
how do i know if its a 64 bit
its new a few month ago !
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 8:53 am | |
| Do you have the laptop to hand and answer your mobile?
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 9:01 am | |
| im at home now call me will pm you, my mobile does not work at home i can not find your number. | |
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 10:52 am | |
| Derek
as its a new pc its almost certainly windows 7 and they are usually supplied with 64 bit windows as it allows more memory to be used than a 32 bit version.
If you have not yet found out then -
Click the Start button then on the right of the start menu Right click "Computer" and left click Properties
about halfway down the properties page under "System" it will say
"System Type: 32 bit operating system" OR "System Type: 64 bit operating system"
If its 64 bit then you cannot make MOTA work on it - at least thats how it was on 3rd August. There are 32 bit and 64 bit drivers available for the dongle, however MOTA itself will only operate on a 32 bit system.
If thats the case, an email to Ian Williams may help to persuade them into releasing a 64 bit version - iwt@iwt.com.au
Mick | |
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 11:11 am | |
| Hi Mick have tried the 32htp thing "but its not working" Ed's has been on the phone phone all night, "trying to help", " But I'm a dead loss.
I have emailed the guy Ian williams and waiting for a responce.
anyway thanks for the support,
I seem to remeber some one asking for an exchange of information, but I can no longer see the post !, anyway "if this could happen on the forum it would be great, mind you looking at all this talk about ch2 d14, octaine and dynamite!!!, I,m sure our formula could be a prime target for pipe bombs and terrorists tuning camps, but its all interesting stuff, I never new about, but does it make us stop and think!.
kind regards Derek
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 11:16 am | |
| found it and yes its a 32 bit ! so hopfully just a dongle or file issue
thanks Derek | |
| Subject: Re: Att Derek - Mota Software Thu Nov 10, 2011 11:31 am | |
| Thats Good
I'd try a new dongle driver next from
http://www.hasp.com/support/hardlock/downloads.aspx
Mick | |
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 1:01 am | |
| Hi Mick,
I think we did try that, maybe not unzipped to the right place or done in the wrong order maybe.
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 8:50 am | |
| Hi Ed & Derek
You can unzip to anywhere you like then just navigate there and double click hldrv32.exe
you may get a message saying the new one is the same as or older than the driver installed
If so go to device manager and delete the Feitian ROCKEY4 drivers, go back and run hldrv32 again
plug in your dongle, it should recognise the device and finish the driver installation.
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 9:39 am | |
| Hi Mick,
I think derek did get that that message reference the driver, hopefully that works or he may get an email back from ian williams saying what the problem is.
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 12:04 pm | |
| tried the first part it did actually change something on ht32
but its still the same error. but i can not find the device manager how do i find it.
thanks for all the support.
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 7:06 pm | |
| Hi Derek
assuming windows 7 and a usb dongle -
click the round start button
type device into the small search box
by the time you have typed about 3 characters you will see Device Manager near the top of the list that appears
Click on Device Manager, then at the bottom of the next list that appears -
Double-Click on Universal Serial Bus controllers
The list will expand to show several devices including Feitian ROCKEY4
Right click Feitian ROCKEY4 and click uninstall - update driver is no good to you as the driver is supplied in an exe file.
Navigate to your downloaded and unzipped driver file hldrv32.exe and double-click to run it again.
follow the prompts and once installed, plug in the dongle - it should be recognised and installation should complete.
good luck!
Mick | |
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 9:40 pm | |
| hi Mick
so far so good going places on a p.c never benn before ! anmyway got allway through to universal bus bit But all the files are YCB AND HOST CONTROLLERS 2934 to 2939 293a293c etc etc and some with boot USD ROOT hubs o yes and two SafeNet Inc, Hardlock key SafeNet Inc, USB Key 8 OFF USB Root Hubs (that all look the same)
BUT NONE WITH THE SAME NAMES AS fetian rocky.
i can just sence we are getting someware with this are we missing a process
and yes its windows 7
best Regards Derek | |
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 11:02 pm | |
| Hi Derek
The Safenet drivers are supposed to be replacements for older drivers but it looks like they wont work with Mota
Your best bet is to install the older hldrv32 driver instead which is still available and we know does work.
Right click the Safenet ones and uninstall them.
Make sure you have downloaded and un-zipped hldrv32.zip then run the hldrv32.exe
it should install ok once the other drivers are removed then plug in the dongle.
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 11:21 pm | |
| where do I find the exe 32 file
hdrv32 yes done that, also removed uninstalled the safnet one#s too, but when I run the others and checked the same they came back again.! what am I doing wrong.
same error 38
help
| Subject: Re: Att Derek - Mota Software Fri Nov 11, 2011 11:55 pm | |
| OK lets go through a check list
remove dongle
uninstall safenet drivers in Device Manager as before
reboot
click start button
type hldrv32 in the search box
hldrv32.zip which you downloaded earlier should appear in the list
Left click hldrv32.zip (one click) to display the contents of the zip file
Double click hldrv32.exe and follow the prompts - watch out for a message in case there is a problem here
reboot
insert the dongle
I dont think rebooting is strictly necessary but it would do no harm and will sometimes overcome install problems
Mick | |
| Subject: Re: Att Derek - Mota Software Sat Nov 12, 2011 9:44 am | |
| hi mick tried all that sure i must be doing it as you say but the same error. ?
thanks hopefullyI will hear from the other guy soon.
| Subject: Re: Att Derek - Mota Software Sun Nov 13, 2011 5:07 am | |
| It is gonna be something silly, Probably something that can be fixed pretty quickly if the computer is in front of the person helping.
| Subject: Re: Att Derek - Mota Software Sun Nov 13, 2011 6:55 am | |
| i have got feeling "you know" heared back today fromian williams he
asked for my dongle serial numbers and for disc.
regards derek | |
| Subject: Re: Att Derek - Mota Software Sun Nov 13, 2011 6:58 am | |
| Well fingers crossed he know's what it is and can talk you through it.
| Subject: Re: Att Derek - Mota Software Tue Nov 15, 2011 5:57 am | |
| Hi Derek,
Did you try it on the xp machine in the end?
| Subject: Re: Att Derek - Mota Software Tue Nov 15, 2011 6:53 am | |
| yes it does not work
| Subject: Re: Att Derek - Mota Software Tue Nov 15, 2011 7:09 am | |
| Now that is very confusing, when i tried it on my laptop yesterday it ran first time no problem
| Subject: Re: Att Derek - Mota Software | |
