| frames | |
+6ol' iron wheels alan ptibbitt125 john bass mjpowell Derek 10 posters |
| Subject: Re: frames Wed Feb 29, 2012 12:27 am | |
| Yes Ned its 001 with its original stand too.. excellent idea.. grab the handlebars roll forward and the stand collaspes on itself.. copied it for 003 so it has the same set up.
| Subject: The Rake Angle...? Wed Feb 29, 2012 3:47 am | |
| I was going to ask, why all the reinforcing plate up at the steering head and Ned virtually answered the question...
The rake angle was changed? and it looks very much as if the front- down tube was replaced with new tube as the front engine plate welding does not look BSA factory standard and there are no holes (for footrest bolt) in that "New" tube -- Am I right?
| Subject: Re: frames Wed Feb 29, 2012 6:38 am | |
| I'm guessing the headstock gusset is to prevent a recurrence of the 002 frame malfunction | |
| Subject: Re: frames Wed Feb 29, 2012 8:22 am | |
| No John the frame was been de-lugged - all the bits not needed were removed. The engine is mounted at a different angle to standard hence new front plates, and an extra lug brazed on for the rear mounting plates. Headstock plates are off a type used since before my time. Two is better than one apparently. | |
adam p
Number of posts : 63 Localisation : fakenham,norfolk Registration date : 2011-03-23
| Subject: frames Wed Feb 29, 2012 8:31 am | |
| hi all, mike is there a jig to produce this type of frame or are they all individually built, is there any information/specs/dimensions that could be posted on the forum ? best regards adam. | |
| Subject: Re: frames Wed Feb 29, 2012 10:05 am | |
| Hi Adam i see you have been doing some frame mods on a trails bantam on the Bsa Bantam Club F/B page.
All frames hand built but in a jig, this sets the headstock and swinging arm pivot. The rest isn't jigged so very much hand built. There are drawings but in the interest of bantam racing I don't think we want any more the same, and in view of Mick Potters recent posts - perhaps things should be done differently. Read Mick Potters posts then p me .. we'll talk.. Mike | |
| Subject: Engine alignment Wed Feb 29, 2012 5:01 pm | |
| How is the engine angle changed ? because the frame loop is at different angle, or engine at a different height ?
I had thought of lifting engine up 1/2 - 1" so gearbox sprocket more in line with swinging arm and rear wheel axle. I have a lot of trouble with trials bike chain tension because of lack of alignment of engine etc | |
Nick B
| Subject: Ex Pete Tibbitts rolling chassis. Mon Mar 05, 2012 3:34 am | |
| Hi all, Had to sneak it in to the cellar in bits. winter o/haul is going well a few new bearings, new paint etc. Cheers for now Nick. | |
| Subject: Re: frames | |
| frames | |
