 One for John Bass....
PostSubject: One for John Bass....   Sun Feb 19, 2012 1:27 am
John do you get MCN in Germany? Very interested bit on the new Ducati GP12
They(journo's and those in the know) that due to its rev's 19'000 its not a 1000cc
but a 925cc? Remember MotoGP are limited to 81mm bore size.
Reasons for doing this - higher rpm, same power as a 1000 but giving slightly less torque
which they can use without the traction control and anti-wheelie cutting in (Much)
Also lighter engine, greater agility and wait for it :- A lighter crankshaft!!!
John any reply to be 2 paragraphs maximum - if you want me to read it! Laughing
PostSubject: No!   Sun Feb 19, 2012 3:43 am
No! I donīt get MCN here -- I did try to get the local newsagent to order it and he bluntly refused, seems heīd lose money....
I have argued all along that it is the amount of instantaneous torque which is the critical factor -- not the lightness of the flywheel*** whoops ! -- gone into 3 lines...
***Sorry about this postscript -- I have also argued that the heavier flywheel aids acceleration in its storing of more energy (than a lighter flywheel) which is used as torque-converted energy during clutch-slipping ....
Yaaaawwwnnn!
All the best!
PostSubject: One for Mike Powell...   Sun Feb 19, 2012 4:11 am
Mike, you said about handling that it depended on rider preference whether he sat in-line with the bikeīs centre-line or hung-out -- seems just what was suitable or -- comfortable ...??
Same with having rider-preference for a low-revving-HIGH-Torque drive out of the corner or having a screamer with the rear wheel spinning. Slick has dealt with them both: one rider wanting high torque and not so bothered about the HP at top-end-- and another who could only ride a screamer. Remember the days of 4 cylinder WSBs being less CCs than the Twins.I was at Hockenheim WSB with Slick and after the last practice he reported loudly to all and sundry that the Ducati was 2 seconds off the pace of the Castrol Honda. In the race the two Ducatis streamlined themselves behind the two Hondas and were 1-2 at the finish by the way they both powered out of the 3 curves of the Autodrome just before the finish.
The speed approaching the Autodrome at the start of the 21st Century was over 200mph -- 206mph by a Japanese rider -- I forget his name -- so the idea of tucking in behind a faster (revving) bike until the finishing 4 corners was truly good tactics.
Humble apologies -- fot this being too long....
CheerS!
PostSubject: Re: One for John Bass....
