 Re: Power to weight ratio
Number of posts : 124
PostSubject: Re: Power to weight ratio   Tue Mar 06, 2012 8:10 pm
Thanks for your interest John I do have John's leathers , I will weigh them and ask my son to weigh his boots and helmet that should give an approximation of race clad rider, as far as the bike's concered I would have to take it to a weigh bridge so we will have to make a calculated guess, maybe someone out there has a weight of their bike that could be used if so please post.
It will take a little time but I will get back to you a.s.o.p.
Sorry this has come new topic I still can't reply post.
Regards.
Les.
foundabantam
Number of posts : 7
Registration date : 2012-03-13
PostSubject: Re: Re: Power to weight ratio   Sat Mar 17, 2012 11:26 am
Hello,
Easy way to find weight of your bike is with bathroom scales, If you get 2 of them and put one under the front wheel and one under the rear wheel and get readings off each and add togeather you should be pretty close. please note to have bike up right and not supported by anything. This can also be done with tank full or empty depending on what you are after.
Hope this helps.
» Aerodynamics plus Power to weight ratio.
» Re: Power to weight ratio
» Best Air Fuel Ratio at Full Throttle?
» Power Steering Gear Box
» Rider Weight for WR250R
