| Crank case transfer port question | |
1bantamcloser2divorce
Number of posts : 36 Localisation : Vancouver Island, CANADA Registration date : 2009-10-06
| Subject: Crank case transfer port question Thu Mar 29, 2012 4:05 pm | |
| Hello , I am hoping I can get some advice from the forum on perhaps what is a straightforward question. I hoping to start building up my engine. I have bought an already ported D3 barrel, which I am putting on (at present) stock D3 cases. I understand it is crucial to match the transfer ports at the bottom of the barrel to those on the crank cases. [img][IMG] My question is, what shape do the transfers ports need to be, below where the barrel and crank case meet? Do I widen the crankcase ports using the same angle as the origional factory ports, or is a different shape more desirable? [img] [/img] [img] [/img] Thanks for your time! Andy | |
| Subject: Re: Crank case transfer port question Fri Mar 30, 2012 4:42 am | |
| Added a picture, in case I wasn't making much sense- quite likley! | |
| Subject: Re: Crank case transfer port question Fri Mar 30, 2012 6:25 am | |
| Matching the crankcase to the barrel is definitely worth while.
Personally I would go for a large radius rather than following straight down with a small radius at the bottom.
Smoothness is more important than a polished surface.
hope that helps
Mick | |
| Subject: Re: Crank case transfer port question Fri Mar 30, 2012 7:39 am | |
| Mick,
Yes, that is helpful, Thanks! | |
| Subject: Where...? Fri Mar 30, 2012 10:58 pm | |
| Where do Bantams race in Vancouver? -- or even in Canada?
John-Boy -- nul-nul, Seven-&-a-Half -- citizen of Canada, UK & Deutschland Überalles!!! | |
andy338
Number of posts : 7 Registration date : 2012-03-11
| Subject: Re: Crank case transfer port question Sat Mar 31, 2012 7:46 am | |
| I am building a Bantam racer to race here in the states. I am planning on racing it in the 200gp class with AHRMA. I currently run a C15 in that class and previously I raced a Triumph Cub. I am building a 125 and a 175 engine.
Andy- not the same one from the original post | |
| Subject: Re: Crank case transfer port question Sat Mar 31, 2012 2:03 pm | |
| - john bass wrote:
- Where do Bantams race in Vancouver? -- or even in Canada?
John-Boy -- nul-nul, Seven-&-a-Half -- citizen of Canada, UK & Deutschland Überalles!!! Well really I am just building a Bantam with a race motor in it. I thought it would be an interesting and relatively inexpensive project. I almost have all the parts after a lot of ebay, auto jumble and craigslist purchases. So I am excited to get going with the build! | |
| Subject: Thanks! Sat Mar 31, 2012 9:00 pm | |
| Thanks young man! I just thought perhaps you would start a Bantam Racing Club in Vancouver. I was ten years in Montreal and it was snowmobile or car racing there with no sign of MC racing.
| Subject: Re: Crank case transfer port question | |
