 Small end bearing.....
PostSubject: Small end bearing.....   Wed May 23, 2012 11:28 pm
Does anyone know if there is a small end bearing to suit a 20mm s/e conrod hole
and a 14mm s/e end ? Make and model and width size would be useful ... Thx
PostSubject: Re: Small end bearing.....   Thu May 24, 2012 8:19 am
hi Mike yes absolutly but surely your not going to suggest using one in a bantam racer ! man are you mad". !!!!!!!
just use 3mm crowded rolleres with washers each side" you Im sure will know this.
I do have one but only use it for mocking up with.
kind regards Derek.
Number of posts : 255
PostSubject: 14*20*10   Thu May 24, 2012 8:13 pm
Mike ages ago when I was using early RM125 pistons on TZ250 rod I could not find a 14*20 bearing, but used two ? FAG or Fafnir 14*20*10s side by side; worked well for 10years or so.
I now use a later RM piston that has 15mm pin and 15*20s are a standard wiseco bearing
