 175 Clutch continued....
BANTAMBUILDER
Number of posts : 24
Registration date : 2010-01-25
175 Clutch continued.... Empty
PostSubject: 175 Clutch continued....   175 Clutch continued.... Icon_minitimeTue Feb 23, 2010 6:49 pm
Hi again,
Does the Bantam Clutch Basket require a band around the outside to stop the sides spreading ?
This is a standard racing modification for the villiers clutch.
How many springs should I use - I have seen some modified with 6, 8 & 9?
I know that RC does an 8 spring conversion kit with thick pressure plate and deeper top plate.
Anyone tried this type with all metal plates ?
Whats the technique for removing the friction material from Surflex Plates ?
SORRY, lots of questions...I know you have heard all these questions before !
Thanks again. Jon.
PostSubject: Re: 175 Clutch continued....   175 Clutch continued.... Icon_minitimeTue Feb 23, 2010 7:21 pm
Hi Jon,
Just about everyone uses 9 spring conversion, panic not... I will take you a free top plate along to the practice day! It will still need a cover to be made up though... There is no real need to put a band round the outside as the top cover does the job of holding the clutch together, but I note that some people do do that particular modification.
Also the centre push mushroom can be modified to take a thrust needle bearing to great advantage as the standard ones are prone to welding themselves together!! and then they are a sod to sort out! See the bantamracer artticles on the main web site for evidence!
ring me if you need help
bounce
» Bird strike
» Last Word...
» Old-timers' reunion.
» Racing/sprinting and the 'child protection act'
» How to toughen up a standard clutch
