 pvl ignition
mark g
Number of posts : 3
Registration date : 2007-07-05
pvl ignition Empty
PostSubject: pvl ignition   pvl ignition Icon_minitimeSun Jul 08, 2007 4:05 am
Hi i have just bought a pvl igntion can i use any pvl coil
many thanks mark.
pvl ignition Empty
PostSubject: Re: pvl ignition   pvl ignition Icon_minitimeTue Jul 10, 2007 7:53 pm
Hi Mark,
I believe that you can use any.
There should be two wires coming from the pvl ignition coil which is the feed from the generator. Some of the coils have a separate earth wire that would go to the frame or chassis as usual.
Some coils I have seen do not have an external earth, this is provided by the mounting point of the coil.
If you put the feed wires the wrong way round the engine fires 180 degrees out of phase, no problem with that! just swap the wires and go again. Usual symptom of this is non starting, and occasional backfire down exhaust!
Hope this helps.
Regards,
mark g
Number of posts : 3
pvl ignition Empty
PostSubject: thanks   pvl ignition Icon_minitimeTue Aug 07, 2007 11:10 pm
Thanks Alan.
pvl ignition Empty
pvl ignition
» PVL ignition
» ignition
» Ignition
» ignition woes
» Mike Powell's 125 Engine...
