 suzuki pe 175 pistons
5 posters
Number of posts : 358
suzuki pe 175 pistons Empty
PostSubject: suzuki pe 175 pistons   suzuki pe 175 pistons Icon_minitimeMon May 04, 2009 5:40 am
afternoon, can anybody tell me how many cc the pe 175 piston (64mm) crown is...save me having to get hold of a burette and then getting it wrong anyway... thanks scratch
SteveF
SteveF
Number of posts : 54
PostSubject: Re: suzuki pe 175 pistons   suzuki pe 175 pistons Icon_minitimeThu May 07, 2009 11:32 am
Assuming you have a standard Bantam 58mm stroke, then a 64mm PE Piston will give 187cc.
Steve
Number of posts : 156
PostSubject: Re: suzuki pe 175 pistons   suzuki pe 175 pistons Icon_minitimeThu May 07, 2009 6:27 pm
std size PE175 is 62mm use this first then you'll have 4 more rebore sizes to save your barrels from being re sleved. That's unless you're on an iron barrel if so go and see Brian White at meeting and ask him to do you a BTW ally barrel, much better in the long run Wink
Tony
PostSubject: pe 175 piston   suzuki pe 175 pistons Icon_minitimeSat May 09, 2009 7:03 pm
thanks for the replies but im trying to calculate the combustion chamber cc for which i need the the value the piston crown is in cc ... ive found someone who can make up an insert for the head if i can give him the cc volume required....
Number of posts : 310
PostSubject: Re: suzuki pe 175 pistons   suzuki pe 175 pistons Icon_minitimeTue May 12, 2009 4:06 am
hi guys,
how do you work out the engine size from the bore and stroke. im stuck figuring it out!
Tim
Sport-Pics
Sport-Pics
Number of posts : 107
Registration date : 2006-12-02
PostSubject: Re: suzuki pe 175 pistons   suzuki pe 175 pistons Icon_minitimeTue May 12, 2009 5:06 am
Pi x Radius squared x height
so 3.141 (Pi) x 1024 (radius squared) = 32768 x 58 (height) = 186.58 cc
Your compression ratio is the volume of the cylinder head divided by the swept volume.
Rusty
http://www.sport-pics.co.uk
» Bantam Clutch Tuning??
» Clutch Centre Bush clearance
» 125 pistons
» Pistons for new 175 engine build.
» will standard barrel take 64mm piston?
