| | Crankcase compression debate | |
+9mjpowell Mick Potter Derek mm_tribsa john bass nigel breeze ROBBIE Trevor Amos alan 13 posters | |
Number of posts : 1748 Age : 95 Localisation : Bensberg, Germany Registration date : 2006-12-06
| Subject: How I wish ... Fri Jul 20, 2012 6:03 am | |
| How I wish we´d had something like this source of technical information way back, 44 years ago. I´d have found time to get into Bantam engine tuning instead of just looking after the bicycle parts and making excuses I was too busy for ought else.
Never mind -- it was a fantastic -- fun(eh, painful sometimes) time, well worth doing.
I don´t say this very often -- I wish I were 30 years younger. No, make that 40.
I found that 1953 article about the Hogan Head and had Luke Filewalker clear me of virus contamination so if young Edward Pickering doesn´t object I shall send him the copy.
But then its really only Old Hat and sickening nostalgia.
JayBee -- John Boy trying to behave!! | |
| | | Edward Pickering
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 6:15 am | |
| Hi John,
No objections, just send it to the yahoo account rather than work one so I can get it across quicker.
| | | ROBBIE
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 8:20 am | |
| Hi all Have measured the ccv and it took 385 cc so that comes out at 1.47 to 1 is this any good for a 175 ? | |
Number of posts : 940 Registration date : 2010-08-13
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 8:37 am | |
| Hey John , I got going in 64 , there was practically no info available then , just a re-hashing of existing practice and virtually no pioneering development . But i`m still here doing techno stuff so the bug bit deep ! Any chance John , that the Hogan article could be posted here for me and others to enjoy , the brothers were truely enthusiastic Bantam boys ?
Cheers for now , Trevor | |
| | | Edward Pickering
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 8:43 pm | |
| Morning Trevor,
As soon as John sends me the Hogan info I will put it on the forum.
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 9:15 pm | |
| Hi Robbie , That volume will work just fine with the bigger capacity , most of the number range quoted come from 125 engines and their multiples , 250 twins , 500 fours and so on. When you stop and think , the crankcase is really a non dimentional chamber , subject to continually changing pressure and temperature . To simplify its function to a basic geometric ratio , that takes no account of it`s max , min or transitory contents , serves to under state it`s complex nature . We all love a specific number , dial it in and you get " x " performance , sadly things are rarely that simple ! The larger cylinder volume will take longer to fill than a 125 of 54 bore , is your bore up around 64mm , pumping that bit harder helps to get the job done in the time available ? Do you have just two transfer ports , if so then the gas flow regime will differ from that of a 3,4,5,6 or 7 port arrangement , and so too will overall turbulence in the combustion chamber at trapping . After saying that , two ports having correct duct proportions and optimum efflux angles will out perform c..p multiple ones . Carefull choice of exhaust system proportions will also pay dividends , but you may have to wield the calculator, hacksaw and welding torch to get things just right ! As they say , there are no free lunches when playing with " simple " twostrokes , and the self limiting nature of Bantams !
Hope that helps in some small way , regards Trevor | |
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 9:25 pm | |
| Morning Ed and John b ,
Many thanks for that offer , i just love this historic stuff , helps fill the gaps in Bantam race development and provides for a perspective of then and now !
By the way Ed , did my email , of yesterday , with pics , get through to you ok , these things have a habit of going astray ? Cheers , Trevor | |
| | | Edward Pickering
| Subject: Re: Crankcase compression debate Fri Jul 20, 2012 10:26 pm | |
| No problem Trevor,
Can't beat nostalgia, sorted my email nightmare so they will be up shortly.
| | | Edward Pickering
| | | | Trevor Amos
| Subject: Re: Crankcase compression debate Sat Jul 21, 2012 1:40 am | |
| Thank you for that Ed , Were it that everything in life was as dependable as Ed ! These two pictures are of the RS case reed set up , in the first , the path to the transfers is direct and reasonably uncluttered even with the piston at bdc , impossible to achieve on a Bantam . On the Gilera, Derbi and ktm clones ( Honda copies ) the reed block to cylinder axis angle is increased to provide an even more direct path. The crank discs interfere minimally with the incomming charge , but ultimately it is the reed block that limits the engine , you can only lift the reeds so far with the energy levels available , the disc rsw has no such problems, a huge uncluttered port at the rear with a 42mm carb feeding it ! The second pic is another view of the same , but the reed housing can be seen to approximate a 90* angle with the cylinder axis , tilt the reed down hill a touch and things improve aerodynamically , and the flow is even less distracted by the crank .
Going slightly off topic , take a look at the ratio between crank disc and main bearing dias , just one reason why a 175 with a big crank and std dia bearings mysteriously doesn`t make the power !
Great topic this , keep it running guys , regards Trevor | |
| | | les2012
| Subject: crankcase compression debate Sat Jul 21, 2012 5:50 am | |
| Hi All, The debate is very interesing but I bet there are a lot of Bantam members out there that have not a clue what you guys are talking about so I would like to poke my nose in. It has been many years since I've been involved but I seem to remember the formula for CCR is fill the engine (with crank in place) with piston at TDC- this includes the volume of transfer ports and induction track, and measure the volume, let's say for this equation the volume being 385cc, now reduce the stroke so the piston is about to open the transfer port then take this volume let's say 256cc then dived 385 by 256 and you will get for what it's worth 1.49. Now, if you want to know if your motor will run better then take out the packing rings, if you find your Bantam is faster then stick with it if not revert to experimentation , for what it's worth JS2 runs about 1,5. but I'm working on a new pipe. Les 2012.
| Subject: Suck it an see -- awful... Sat Jul 21, 2012 6:21 am | |
| The "suck it and see" sort of development is awful & soul-destroying. Having a dyno and sticking to one change at a time is the right way and wonderful way to do engine development. With no dyno and rushing off to a test track every so often is a long-winded way of getting the job done. Plus, if the change didn´t work a whole day of the "Two day flu" ***would have been wasted.
***We had what was known as "Two & Three day flu" at Ford Dunton -- no mediacl certificate needed -- and I was frequently at Brands feeling dreadful. Not because of flu -- because the change didn´t bring expected improvement.
| | | Ned
| Subject: Re: Crankcase compression debate Sat Jul 21, 2012 11:02 am | |
| Aint that the truth John ! Every time I see you post one of your formulas I think. You as a Ford engineer and me as a Ford fitter mechanic both know. Ford coined the phrase 'Teething trouble' when their engineers found theory and practice didn't always coincide Pulled a few sickys as well John, I only found out my supervisors son was a biker when my supervisor told me how he knew I was in the IOM while I was off sick | |
Number of posts : 1065 Age : 63 Localisation : worcestershire Registration date : 2007-06-15
| Subject: Re: Crankcase compression debate Sat Jul 21, 2012 11:25 am | |
| Hi Trevor I could not resist this one, trevor you use the words Impossible ! my own personal feeling is nothing is imporssible, a little difficult may be but not impossible. love the photo;s I bet no one has spotted what I have, the other thing having work for some considerble time in afoundry and machining casting its amazing the technology in making these cases and barrels, not just std casting process these are precision investment cores not just normal silica sand these are very high cost items.
2) the other think on you point about the fly wheels as they are travelling in the same direction as the gas flow what differenece does this have sure this will improve what your talking about.
3) I have tilted my barrel forwards 15mm to improve this aspect, Im quite please my think was correct then, I was also onto the inner ducts but not to the level or knowledge we have know. but I did do this well DAD did in about 1985/6 it was some years later before it appeared at a race track 90, in it first face it seized just starting the last lap, I think whch was about the time I solid my current bike/engine to Keith Andrew.
4) I hear those disregarding this layout for a fast bantam, I completly disagree with this, Andy Moldens bike went resonbly well, as Mike says, but ours was a lot stronger in all area except perhaps handling. I still intend to push on with as my winter project for next year, even though this engine/bike, dimmed the light for me and ended my passion for tuning and racing my Bantams, just too many issues to resolve, with a lack of knowledge / understanding / no time and perhaps a lack of experience, to resolve them. I had the best machine shop, we re machined the cases on a newall jig borer at lucas aero, things are different now, but the dyno readings proved it had loads of power all through the rev range and torque it had such a wide spread.
the crank reed engine is not dead, its just in the que in the shed waiting behind a few parts to be sorted, along with a few other bits and pieces, for my new bike and eds Bike and the sprinter looks like its comming out next year too, along with my twin disc set up, for me 175, I always wanted to do this, hopfully this will also be out soon, not sure about you guys but it taks loads off effort to do things with limited resources, in not having a full machine shop to hand, so its a trip off to the local eng shops or down to dads when somthing needs doing I cannot at home.
well thats what Im working on so what are you guys working on and doing now or next year lets see some pictures.
| Subject: Re: Crankcase compression debate Sun Jul 22, 2012 1:53 am | |
| Hi Derek , Just a couple of points , the flywheels , themselves present few problems , it`s what comes off their periphery that is the problem . Any rotating disc will move air , if that air contains petrol and oil it will have mass and density , a rooster tail of gas will centrifuge off the disc and , in the case of the RS , collide with the inlet charge flowing through the reed block , turbulence ensues, bulk flow falls and consequently , power drops . Covering the crank has proven to assist flow , but you have to balance this with lubricating the various bearings , so take your pick ! I have never , and would never , suggest that Bantam case reeds doesn`t work ! What they do bring is a huge amount of work needing specialist machining facilities and so on . What they don`t bring , so far , is any advantage over the much simpler alternative of a cylinder reed , eventually the whole set up is compromised by poor gas flow , and dodgy carb installation ! However , i wish you well with your personal project and look forward to seeing it on the track .
The project i am working on may interest you , it is based on a BTW barrel and head . The inlet port has been filled to accomodate a correctly positioned duct alligned with the reed valve and is a development of current practice . The exhaust duct has had a multi bore run up it and a sleeve with tripple ex ports shrunk in , a second sleeve forming a new bore incorpoates more of the tripple ex port arrangement , the inner transfer duct profiling and port angles , with , the last part of the inlet tract . The original barrel, which is little more than a finned sleeve , has had some judicious in- fill of weld , awaits cnc milling of the outer transfer ducts and subsequent heat treatment . when the whole lot is assembled , treated , and final machining done , the bore will be Nicasil plated . Other things like stud position , extra case screws , gearbox bearings , clutch basket and so on will be upgraded , i may go for an inserted head with a torroidal chamber , a watercooled head is also a consideration . Thinking long term , a modified near side gear box mod with a detatchable insert housing could offer extra , sleeve gear , output support and complete gearbox removal with the engine in situ . The whole project is designed to produce power with relibility , the time scale is open ended and is determined more by funds than much else !
Sorry Mike P , i have just re- read the whole topic and realised you asked a question and i have failed to reply , i will get down on that !
Cheers to you all , Trevor PS , you are very quiet on this Allan , any thing to add , after all you are the instigator and perhaps the main beneficiary ?
T
| | | mjpowell
| Subject: Re: Crankcase compression debate Sun Jul 22, 2012 3:34 am | |
| Hi all, Dereck you mis-quote me I said ' Andy Moulden bike goes like a rocket!'
Its also faster than mine and if the motor had been in my frame the exhaust would not of decked out and races would of been won and lap records would of fallen I feel?!
Trevor , no worries ref post just interested on your take on the(disc) subject. Also my next bantam motor is a BTW cylinder/head featuring inlet tract reed, some parts have been acquired but not a lot of thinking/work has gone into it yet. Going air-cooled to save weight - no rad/water/pump/battery - hope to get it down to 72kg dry!
| Subject: Answering Ned... Sun Jul 22, 2012 6:13 am | |
| Hi Ned! I knew Ford engineers before Dunton and it was a Dunton Supervisor who guided me into taking interest in Bantam racing, then making a Bantam racer. I have described my time there in Testing Operations as the most boring 4 years of my life. But if I´d not gone to Rainham (before Dunton) I´d have never have known Bantam racing nor road-raced at all and would have the missed the fabulous experience of actually RACING the ABS 250 against Greeves Silverstones and the like.
During my time at Dunton the development engineers were "Component Engineers" which meant each one only worked and developed one component in conjuction with a new model´s other engineers. It was a cock-up in my opinion.
Did you ever hear of Alex Macfazdean? who went sidecar passengering and did some record breaking with his own home-made streamlined, cigar shaped special. He had a Norton-Wankel (rotary piston) engine in it at one time. Alex had "3 Day Flu" during which time he looped his record-breaking-special on Pendine Sands and poor -- now sick -- Alex had his disaster pictured on the middle page spread of the next edition ofMotor Cycle News whilst he was still off sick, nursing his bruises and concussion... I made my steel-boot sole (for Speedway practice) at Alex´s place and I cannot remember the name of it now. Anyway Alex was doing very well with his own engine recon business in 1986 when I saw him last. Can´t remember the Essex village now -- was south of Dunton....
Keep well, JayBee... | |
| Subject: Re: Crankcase compression debate Sun Jul 22, 2012 6:56 am | |
| Hi Mike , Sounds like a good project , i did a fair amount of number crunching on heat build up , the big problem could be assymetrical cooling from the angled ex duct and lack of finning there . Heat saturation can build up very rapidly and cause real problems with distortion . We will both have a problem there but i suspect you`ll be on the track befor me , best of luck . Can`t argue with weight reduction aspect , that alone will reduce lap times . Strategic air ducting may help a lot here with shifting heat mass but keep hot air away from the carb bell mouth , ingesting hot air is a real no no .
Good luck , Trevor | |
| | | les2012
| Subject: crankcase compression debate Sun Jul 22, 2012 7:38 am | |
| Hello JB Yes I agree with you suck it and see is not the way to go, dyno is the way BUT!! what would you sugguest to anyone who has no access to a 2 stroke dyno. How would you advise to test the changes?. How would you know if the idea's one had would work?. I for one have no access to a dyno, I've checked in my area but only 4 strokes therfore I ask your advice. How can I evaluate the changes made to JS2 without the use of a dyno?.Test days at Brands on the odd occasional visit,a race day with the club?. please advise. Les2012. | |
| Subject: Worse than angling... Mon Jul 23, 2012 5:27 pm | |
| Its worse than going fishing Les -- a lot of patience needed if you develope just by track testing. I´d set out with two others to get a Bantam racer made & on the track and so in being tester at Brands one & a half seasons didn´t seem too much. I just enjoyed the practising -- except for piston profiling which was a pain .. ... ....! ...As well as assessing what one-change-at-a-time meant there was the weather conditions to correct for and a lot subjective feelings to cope with. Because I was far too overweight the effect of me slimming down had to be taken into account -- I knocked off 3.5stones in 6 months which probably accounts for my current longevity!!
I editted this at 11.03 (knowing that I had access again to the site...) -- The point above is very important -- if you are testing changes at the track they really have to be done on the same day (or correction factors applied, same as on dyno...). As the weather is this year (the temperature and humidity have had wild swings) a change for the better -- or worse -- could go unnoticed unless the performance was corrected and that comes down to sensible guessing because correcting is very difficult to do on the track. I made a telescoping, parallel section for my first resonant pipe. With this I was able to get a good approximation of the length that worked the best -- with the particular transfer port shapes and all timings at taht moment... Then we made several small changes with ports and timings using that one pipe until the seeming optimum was reached and then repeated the lengthening & shortening exercise again... until I had a high torque motor, for my weight -- with reliabilty. With Brands practising on a Wednesday -- in those days -- there were 4, half-hour sessions during the day with cars and sidecars in the other 1/2 hours. This meant I could get enough testing in -- in one day -- to be relatively happy with the results.
I quite often enjoyed Brands-test-days more than race meetings because there was no fuss about scrutineering and so on -- you could do it at your own pace -- and there were always bigger street bikes to chase and beat up. Better stop now or I´ll go on for ever....
However! The fact that I seemed to be going well at Brands -- particularly against Café Cowboys on Dommies and Big Triumphs had me thinking I´d be a Bantam Club champ... Not with an estimated (by timing the accelerations) 12 bhp ... No way!
Good luck" Cheers! JayBee = John-boy!
| | | mjpowell
| Subject: Re: Crankcase compression debate Tue Jul 24, 2012 2:50 am | |
| Ref my earlier post Air cooled lightweight bantam (which has been edited now) should of read 72kg not 62kg! Think we'd struggle to get to 62kg :-)
Mike | |
| Subject: Re: Crankcase compression debate Thu Jul 26, 2012 12:12 am | |
| Mike just to correct you - I never miss quoted you !!! - bettsd wrote:
- Hi Trevor
, Andy Moldens bike went resonbly well, as Mike says, Derek | |
| Subject: Re: Crankcase compression debate Thu Jul 26, 2012 1:29 am | |
| Hi Mike , Exactweld , great bike and in it`s day the fastest 250 in Europe , such a shame the money ran out. The twin carb , per cyl , set was also tried by Kriedler back in the sixties , but seems to be lacking in any clear advantage . In the case of Exactweld , with four carbs , setting them up must have been a real headache . Fundamental research by the Aprilia team has proved that a disc set up needs a specific case volume to produce the power when relying on the diff to pull the fuel through . Being able to predict and control the most favourable inlet timing , the exhaust can be maximised to work in concert with that and , having a case volume that is not too big or small , masses of gas can be inhaled . Stick in a massive ex port with power valve control and the whole package works with perfect harmony . However , under or over the clearly defined power band and the whole event goes haywire , combustion residues go out the carb bell mouth with reverse flow and , exceed the over rev limit and the engine just stops effective running .
The change from side to rear discs throws up some interesting points , the side job , RSW , has to induct through the case transfer duct and the con rod clearly obstructs flow into the engine . The rear disc ,RSA, eliminates both , now the RSW used a 115 rod and the RSA a 120 , in countering the longer rod , and supposed increase in case volume , the side disc had beveled crank wheels and the later , rear, had straight . So perhaps Jan and the team hit upon a working volume and adjusted the geometry to accomodate it ? Bulk flow into the engine via the rear disc must be superior but driving the opperating mechanism equally must absorb power , especially when spinning a dizzy 13500rpm , from the dyno graphs that i have seen the RSA only produces a little more power than the RSW but maybe thats all it needs to keep winning !
A piston port nor reed can , for differing reasons and in a three speed environment , use much of this technology , it seem still that we carry on in the time honoured way of the garden shed tuner , picking up on snippets that may or may not take us forward .
Take care out there , Trevor | |
| Subject: Re: Crankcase compression debate Fri Jul 27, 2012 9:50 pm | |
| Hey Mike , A 125 rod on a 54 stroke , now what can the radical thinking behind that one be ? The Bantam world is on tenter tenter hooks ! The implications leave me confused and worried , not a good thing at my age !
Regards , Trevor
| Subject: Uh OH! Sun Jul 29, 2012 9:32 pm | |
| Uh Oh! Come on Trevor? -- you know already...! -- "...it´s all to do with time taken...," you said -- might not be an exact quote but the meaning was there. To be or not-to-be... that is the question...
...Quicker thro´ BDC or slower thro´BDC...?? ... Slower thro´ TDC or quicker thro´TDC...??
Leave it until the lads get back from racing...
Cheers! JayBee -- ever trying to behave .... | |
| Subject: Re: Crankcase compression debate | |
