| Clutch for 175 Racer | |
BANTAMBUILDER
Number of posts : 24 Registration date : 2010-01-25
| Subject: Clutch for 175 Racer Sun Feb 21, 2010 4:55 am | |
| Hi,
Work on my rolling frame is nearing completion - need to start gathering bits together for the Clutch and Engine build.
Crankshaft, Bore size, Piston, Rod, Ignition, etc is all sorted.
Are you all using modified Bantam Clutches ?
All Metal Clutches ? Surflex Plates ? extra strong springs, etc ?
I have had quite a bit of experience with Villiers clutches used in 210cc kart racing - these use a billet clutch drum, wet Surflex Plates and 9 x VERY stong springs to prevent slip !! A modern 210 long stroke engine is good for almost 40 HP.
What sort of BHP does a good 175 make ?
Any help with obtaining the bits would be much appreciated.
I will come up to the Test Day on March 5th - hope to meet some of you there and have a look at the bikes.
Many thanks to Alan and Robbie - their combined advice has got me this far !!
Thanks, Jon | |
| Subject: Re: Clutch for 175 Racer Sun Feb 21, 2010 8:01 pm | |
| All metal Jon, the fellas at practice day will put you right, in the mean time have a look through Alan's wonderful site to see some plates he's converted to all metal
http://www.bsabantamracing.com/bantamracer/bantam_racer_3.htm
Good luck with the build
Tony | |
| Subject: Re: Clutch for 175 Racer Sun Feb 21, 2010 8:30 pm | |
| Hi Jon, At th practice day see me (yet again!!) for clutch springs!!! I have a batch of extra strong ones made up every year and keep them with me when I go racing. I may not actually be riding at the practice day, so you will be able to find me via other bantam riders that are there. Cheers, Alan | |
| Subject: Re: Clutch for 175 Racer Sun Feb 21, 2010 8:40 pm | |
| Hi all,
Just a quick question to ask, can you use a 175 clutch inside a 125 motor? Seems you can get more plates in plus better efficiency.
Tim | |
| Subject: Re: Clutch for 175 Racer Sun Feb 21, 2010 9:32 pm | |
| Hi Tim less plates the better I find the smaller basket is the one you need | |
| Subject: Re: Clutch for 175 Racer Mon Feb 22, 2010 2:18 am | |
| Ahh ok then. Cheers for that. I've got 3 small clutch baskets all with new plates in etc so I'll use them then but I will change the springs to heavy duty for non slip.
Tim | |
Greenbat
Number of posts : 47 Registration date : 2008-03-11
| Subject: Re: Clutch for 175 Racer Tue Feb 23, 2010 5:07 am | |
| I believe you sometimes use the old style cork plates with cork removed? I have several, if anyone can use them I'll give them to you (they're in the bl**dy way!) | |
| Subject: Re: Clutch for 175 Racer Tue Feb 23, 2010 7:00 am | |
| Hi Greenbat, we use the surflex type without the surflex cork and then with slits in them, the real early types with cork inserts are junk! See the bantamracer articles on the main bantam web pages and you willunderstand more! Alan | |
| Subject: Re: Clutch for 175 Racer Tue Feb 23, 2010 7:03 am | |
| Alan, do you know where I can get the metal/surflex plates from? I've seen you do heavy duty clutch springs that you sell(?) and that you can grab them from you at meetings, are you going to be at Mallory on the 5th April? | |
| Subject: Re: Clutch for 175 Racer | |
