| Fuel injection or Ram air.... | |
| Subject: Fuel injection or Ram air.... Wed Apr 13, 2011 7:13 pm | |
| A couple of pic's from the South East centre archive (thanks Les).. Fuel injection - Ram air bantam style - | |
| Subject: Re: Fuel injection or Ram air.... Wed Apr 13, 2011 9:02 pm | |
| WALL FILLIPS FUEL INJECTOR /CARB MONOBLOCK HARDLY RAM AIR mIKE !"SOUNDS LIKE A LOAD OF HOT AIR TO ME" ! | |
| Subject: Re: Fuel injection or Ram air.... Wed Apr 13, 2011 11:20 pm | |
| Nice photos Mike. On the subject of ram air I was thinking of a system where you drill two holes in the fairing, then make a sort of flange up which 2 insulation pipes will be secured with Jubilee clips. Then screw the flanges with the pipes attached to it through the fairing, and glass fibre it over. Then you have a sort of ram-air-type cooling system. One pipe can go to the carb and the other pipe can go to the head/barrel etc. I could do you a drawing if needs must lol..
T | |
| Subject: Ram Air or Hot Air? Thu Apr 14, 2011 5:26 am | |
| Racer, name of Bostock -- Harry, I think -- had the cylinder head with his SpeedTwin(?) Triumph reversed, fitted back to front. An article in The Motorcycle (the Blue `Un) said Mr Bostock was quite disappointed with the performance and commented that "... perhaps the air currents from the rotating mass of the front wheel caused eddies around the carbs that in effect reversed the ram-effect." ... Tricky in the rain I´d think? but then everything is... The Exhaust Ejector however, did work -- but hardly enough performance to justify the increase in weight addition .... Cheers! JayBee for John-Boy. | |
| Subject: Wal Phillips "Injector" Thu Apr 14, 2011 7:20 pm | |
| Can´t let this go by, unanswered. The Wal Phillips device was really a carburettor less float chamber. Rather crude but worked very well when properly tuned. There was no question of "injecting" except if you allow that the fuel was `injected into the mixing tube by the pressure-head of fuel above it´. He was an unforgettable character -- a laugh a minute, expecially when you forgot to switch off the petrol when the engine stopped ... It was the high probability of the device causing a fire that prevented full scale production. Cheers! | |
| Subject: or water cooling Sat Apr 23, 2011 8:43 pm | |
| Here's an early water cooler - but with air-cooled head!? | |
| Subject: W/C Barrel A/C Head...! Sun Apr 24, 2011 4:45 am | |
| In my opinion there is not the same necessity to water cool the head in a two-stroke engine as there is in 4-stroke motor. As long as the air path is adequate the finning should be sufficient. In a 4-stroke head you have the effect of a very hot area (exhaust port) and cold area (intake port)close together within the mass of the head whereas with the two-stroke, air-cooled head, the `cool´-air first comes up to the hottest part of the head (first) and flows thro´ the fins to the cooler part last thus optimising the balance of temperature difference across the cylinder head.. ... The Andy Boyle Special with 250 Alpha `Works´ engine had air-cooled head and water-cooled barrel and was as quick or quicker than a Greeves Silverstone. I think the reason was the head being out of the water-cooling system the control of barrel-distortion was facilitated easier with more simple and clever waterways. If I´d not been so selfish and accepted a fantastic job -- with enormous promotion in Montreal -- the ABS might have become a fully developed racer. As it is The Andy Boyle GP5 -- based on the ABS original data has done very well recently.... | |
| Subject: Re: Fuel injection or Ram air.... | |
