 Piston travel vs crank rotation
4 posters
Jimmie
Number of posts : 166
Piston travel vs crank rotation Empty
PostSubject: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeSun Jun 24, 2012 7:35 am
Came across this 'tool'. I assume it is only one of many. Can anyone say how accurate it is?
http://john.rushworth.com/Pics/Piston/
PostSubject: Re: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeSun Jun 24, 2012 9:17 am
looks spot on to me. Gives exactly the same results as formulae from Bell's book.
mick abbey
Number of posts : 7
Registration date : 2011-08-11
PostSubject: Re: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeThu Jun 28, 2012 9:12 pm
Yes it is spot on I have done a quick test with it and it is right
http://www.mickabbeytuning.co.uk
mick abbey
Number of posts : 7
PostSubject: Re: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeThu Jun 28, 2012 9:13 pm
Jimmie
PostSubject: Re: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeThu Jun 28, 2012 10:55 pm
How do I calculate timings for an exhaust port which ‘opens’ say, 40mm below the top of the barrel (62 bore and 125 rod). According to the chart this gives a timing of 100 degrees. Do I subtract this 100 from 180 and the double it, ie 80 x 2 =160 degrees exhaust timing?
PostSubject: Re: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeFri Jun 29, 2012 1:09 am
Hi Jimmie
Yes you are thinking on the right lines to calculate total opening angle for an exhaust port.
I guess you intended to say 62mm stroke rather than 62mm bore?
For a 175 Bantam with 58mm stroke and 125mm rod length then 40mm after tdc is about 105.7 degrees after tdc so the total opening works out at 148.6 deg.
The web page takes no account of any gudeon pin offset but for most pistons its between 0 and 1mm so only makes about 0.1 degrees difference to the opening and closing times and the total opening remains much the same.
Jimmie
PostSubject: Re: Piston travel vs crank rotation   Piston travel vs crank rotation Icon_minitimeFri Jun 29, 2012 3:40 am
Thanks Mick. Them hard sums are really hard!
Jim
» D5 crank shaft
» Crank bearings
» B175 Crank
» crank pin hole
» Heavy Crankshaft....
