 B175 Crank
Brunow
Number of posts : 2
Registration date : 2010-01-11
B175 Crank Empty
PostSubject: B175 Crank   B175 Crank Icon_minitimeMon Jan 11, 2010 5:30 pm
Hi,
I need some info about the B175 bantam crank.
The "plate"70-7796 is loose from the crank.
Pic's : http://bsabantam.blogspot.com/2010/01/19-plate-and-how-do-you-mount-this.html
http://bsabantam.blogspot.com/2010/01/b175-engine.html
How can i remount it?
Thanks.
B175 Crank Empty
PostSubject: Re: B175 Crank   B175 Crank Icon_minitimeMon Jan 11, 2010 7:12 pm
Hi Brunow,
Just throw the disc away! you do not need it at all and there will be no change to the performance of your bike at all!!
If you really really want to have it on.... then the edges of the crank wheels need to be punched to crimp the disc in place. They regularly fall off in use, so the better deal is to scrap 'em!
Brunow
Number of posts : 2
B175 Crank Empty
PostSubject: Re: B175 Crank   B175 Crank Icon_minitimeMon Jan 11, 2010 10:19 pm
yes sir! clown
B175 Crank Empty
PostSubject: Crank disc   B175 Crank Icon_minitimeTue Jan 12, 2010 7:27 am
I agree with Alan. In my 37 years of Bantaming I have had to repair several sets of crankcases due to the discs coming loose. A retired NZ dealer friend was almost bankrupted fixing D14B warranty claims due to the rivets failing.
After the later D7 and some earlier D10 models the discs were added with the intention of closing off the dead space in the crank flywheels so reducing crankcase volume, increasing primary compression ratio and efficiency. But they are not gas tight, volume remains nearly the same.
So leave out, or if rebuilding crank get some good thick plates made, machine the crank lip off, a step inside, clear of the seal diameter and hold on with countersunk cap screws loctited in. Beware the flywheel material is hard and can only be drilled/tapped slowly and carefully. Spark eroding out broken taps is expensive !
I have had this done this on my trials D7, road B175 and racing D14 cranks.
B175 Crank Empty
B175 Crank
» crank pin hole
» Standard port timings
» Taper head race D14 / B175
» Heavy Crankshaft....
» D5 crank shaft
